Saamah
Hi all,
I'm looking for a smartwatch for my elderly mother with which she can make calls if she has an accident at home. I think most of the top smartwatches can do it, but getting something that measures heartrate/has a camera etc. is a bit overkill. So can anyone recommend a simple smartwatch that:
- can make phone calls (either using it's own SIM or by connecting to an Android smartphone)
- has a good battery
- is reliable (not like those cheapy DZ09 ones)
- ideally can be voice activated (i.e. you can install Google assistant or something similar)
This is for the UK.
Thanks so much and merry christmas
Saamah
This is for the UK.
Saamah
