i am looking to build a complete new system with a big led screen (50+) mounted on the wall, is it neccesary to spend a lot of money on a high spec tv to get the smart stuff when i believe that for less than £200 a dvd/blueray player provides the same?
Is there any benefit to having different makes of tv and blueray to get the option on features, or is it preferable to stickwith one supplier?
Everything will be linked to a sony 3600es receiver to provide the surround sound
Any recomendations on which cables i should bury in the wall to connect everything?
I am just using freeview and not satelite
I will also be connecting an xbox 360 slim with connect, does anyone know if the connect sensor cable is a standard usb, as i need to extend it?
Any info on the points above greatly appreciated
