Smart TV advise!
Discussion in 'What Is The Best TV For You?' started by OwenPan, Aug 14, 2013.
  1. OwenPan
    OwenPan
    Aug 6, 2013
    82
    Manchester
    I'm looking at getting a small tv to mount on the wall in the kitchen.
    It must be a smart tv as I want to connect to the internet using wifi. Mainly so the mrs can look up recipes as she cooks. So a user friendly browser would be ideal.
    I also want it to connect to a wireless keyboard. Preferably the apple keyboard as I like its simplistic styling.
    Any advise comments recommendations would be great.
    Thanks Owen
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  4. jnorth
    jnorth
    Aug 10, 2013
    That TV have a dual core processor, so the speed of the browser should be alright, more responsive than last year models .
    I was particularly interested in quality of a browser on new LG models, so I had to test one. I have to say it works really well. They have their limits, mostly memory related (if you have few tabs with flash open they will slow down to a point of not being usable).
    My advice would be either that model that vickster recommended, or LG LN575V. Since you are planning to wall mount them, keep in mind that both models are a bit thicker.
  5. OwenPan
    OwenPan
    Aug 6, 2013
    82
    Manchester
    I was looking at a 24" Panasonic, TX-L24X6B. Mainly because I have a 47" DT50 already, the IOS app isn't bad and the browser is good. Wasn't sure how comparable a high up model would be to a smaller tv.
  6. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Doubt the Panasonic is full HD? The X models are mostly HD ready
  7. OwenPan
    OwenPan
    Aug 6, 2013
    82
    Manchester
    Good point, I had seen that but forgot. The LG and Samsung are looking like a good bet.
    Do you know if wireless keyboards can be used? Never had the need to so don't know much about it, or would you stick with the supplied iOS apps?
  8. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Don't know, sorry. I use a computer/iiPad/smartphone for the web - TV for TV
  9. cotton
    cotton
    Dec 26, 2011
    4
    @OwenPan
    So what did you opt for in the end, given that the Samsung was 2" smaller than the Panasonic?
