Smart Sympodium ID350 - Interactive Pen Displays
Ideal for small desktops or lecterns, the versatile ID350 has a 15" (38.1 cm) screen that lets you write over any presentation in digital ink, highlight concepts and take notes. Your audience will see your writing projected onto a large screen as you deliver prepared or impromptu material.
You can still work with the software you're used to – such as Microsoft Word, PowerPoint and Excel, or even your Web browser – and save all your notes afterwards. The ID350 is simple enough for anyone to walk up and use, but with enough features to satisfy your most demanding requirements.
Interactive screen
Control your computer with the pen tool and write over any application with digital ink.
Save function
Capture your work into Notebook software or save notes directly into several software applications, including PowerPoint, Word, Excel and AutoCAD software.
Battery-free tethered pen
Write smoothly and comfortably with the attached, battery-free pen.
Pen-tool and function buttons
Use buttons to change between ink colors and the eraser mode without crowding your display with toolbars.
Notebook software
Create, organize and save notes, drawings and screen captures. Import PowerPoint slides and edit them in Notebook software, or export your Notebook pages to PowerPoint software
SMART Board tools
Add even more features and flexibility to your interactive whiteboard session. Customize settings, type with the On-Screen Keyboard, write over digital video and much more. Features include LinQ™ software, Start Center, SMART Video Player, SMART Recorder, Floating Tools, Spotlight and Magnifier.
Function buttons
Quickly access the right mouse button, On-Screen Keyboard, Screen Capture tool, Floating Tools toolbar and Notebook software.
On-screen display buttons
Fine-tune the display properties to suit your needs.
Adjustable tilt stand
Position the interactive pen display at a comfortable viewing angle.
VESA mounting plate
Use a variety of VESA mounting arms to permanently mount Sympodium interactive pen displays on furniture – the ID350 can use any 3" (75 mm) and the ID370 can use any 4" (100 mm).
USB computer hook-up
Easily connect the ID350 or ID370 to your computer
High-speed USB ports
Connect up to two external USB devices, such as external memory, mouse, keyboard, headset or document camera.
Weight (KG) 4.6
Size (mm) 299 x 343 x 48
Colour Black/silver
Additional features Desk stand
£450 - p&p
PDF datasheet Smart_sympodium_ID350_ID370.pdf
Product page:
Interactive screen
Save function
Notebook software
SMART Board tools
Function buttons
VESA mounting plate
Weight (KG) 4.6
Colour Black/silver
£450 - p&p
Code:
http://www.rapidspread.com/file.jsp?id=uhsqwpmc5w
Product page:
Code:
http://www2.smarttech.com/st/en-US/About+Us/News+Room/Image+Gallery/Sympodium/Sympodium+ID350+interactive+pen+display.htm
