Dear all,
I would be grateful for your advice to a smart home "newbie".
I would like to add "smart" functionality to the outside lights at the front and back of my house (the outside lights will be fairly bright spot lights). In an ideal world:
Grateful for any advice/tips you may have.
Many thanks,
Ilan
- for the outside lights at the front of the house I would like:
- ability for lights to come on when my wife or I drives into the driveway in the evening (I think the functionality is called geolocation)
- ability to turn lights on or off remotely using smartphone
- ability to set time for lights to automatically come on and go off
- in the evening movement to trigger lights going on
- for the outside lights at the back of the house I would like:
- ability to turn lights on or off remotely using a smartphone
Many thanks,
Ilan
