SMART II Calibration Package
Discussion in 'Home Cinema Buying & Building' started by Pip_UK, Aug 13, 2002.
  1. Pip_UK
    Pip_UK
    Got a shock when my parcel arrived this morning. I had to pay £17 import VAT.
    Thought I would post this so anyone contemplating purchasing this package doen't get a shock from the postman!
    Pip
  2. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Hi Pip,
    Thanks for the info! I'll be ordering mine soon.
    Have you performed the calibration yet/added the filter? Did you get good results? Was it an easy process?
    Mark.
  3. Amelia
    Amelia
    Is "SMART II Calibration Package" for Pal ?
    Regards
    Amelia
  4. Pip_UK
    Pip_UK
    Mark ... not calibrated yet as pj is with Sony due to a fault.
    Amelia ... I think it is more to do with improving display but not 100% sure. Maybe someone else with more knowledge/experience can answer your question
    Pip
  5. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Funny you should mention your 11HT being at Sony for repair as mine is too (well it might be replaced, but they've not decided yet) :mad:
    What's happened to yours?
