Smart home - lighting, CCTV, heating etc?
Seb Briggs
I suggest you possibly invest in a mock-up system to ensure you and maybe your electrician can play with and understand the system
its what I use for testing
light fitting (ideally the one you are likely to use in the ceiling)
Varilight/scolmore Switch
Shelly Module
Wired into a standard plug and lead
Seb Briggs
With regard to your scene question.
This may be a little hard to grasp initially (sorry if that's condescending) but Shelly have a module called an i3. This is just for scene control and allows up to 3 switches to be used as scene controllers with each switch having multiple actions each potentially running a different action or scene.
ie
1 click - All bedroom Lights Off
2 clicks - Turn Off all lights at home
3 clicks - Close Blinds
It requires 240v power (Line and neutral) and ideally would be used with 2 position retractive switches
More details here
Smurfin
ie
More details here
Not condescending at all...I don't understand the technicalities behind this stuff :)
To prove my point....here's a dumb question ;)
To if I want to add scenes, effectively I need to add one of these modules to each room, for up to 3 switches?
You mentioned particular switches for dimming control yesterday, do you have any links to varilight versions?
Seb Briggs
So if I want to add scenes, effectively I need to add one of these modules to each room, for up to 3 switches?
Yes if you want to control scenes via a switch, obviously you can use voice or app as well.
Using the Varilight (or scolmore) modular grid system you can have both actual light switches and scene control switches on the same plate.
For dimming
https://www.myswitchshop.com/index.php?main_page=product_info&products_id=7541
For scene control
Seb Briggs
Finally, for the moment, Shelly also have a motion and lux sensor so you can further automate lights on/off
ie if motion detected and lux level below 100 then turn on living room light
Smurfin
For dimming
For scene control
So if I'm not bothered about scene selection from the switch and just via voice or app, I don't need that scene module?
Smurfin
Another question...let's say I have some artwork that I want highlighting - I used to use angled GU10s to do this.
In my Rako system I used to have the art lights on a separate circuit.
I'm wondering if there's a better way here....how about if I had all lights in a room on the same circuit, but just used a smart bulb like Philips Hue or something similar as the highlight lights. Does that make sense to do?
Seb Briggs
yes that is correct, it was really just an answer to your question earlier regarding what you could do with Rako and that it was possible
Seb Briggs
If it was me i'd still have it as a separate circuit but technically you could do what you say.
The problem being if you turn off the other lights you wouldnt then be able to use the highlight lights
Smurfin
Yes I get that, just thinking in those situations I would rarely have all of the other lights off, I'd just have them on a low brightness, with the art spot on full.
So right now my initial electrical works are looking like this:
Bedroom 1
Spotlights in ceiling on one circuit (Shelly dimmer2 x 1)
Pendant bedside lights on their own circuits (Shelly dimmer2 x 2)
Light switches either side of bed (3 x gang - what varilight plate would I need, brushed steel finish?) with 3 G102SRS in each
Light switch by bedroom door (1 x gang, with 1 x G102SRS in it)
Bedroom 2/3/4
Landing
Shelly motion sensor (for kids coming out of their rooms at night)
Have I got that right? Just not sure what switch plates to go for..
Smurfin
Just to clarify, where I'm just replacing the existing wall switch with the new one, I wouldn't need to change any wiring to those switches with the shelly dimmer2s?
Seb Briggs
There's a question !!
That will depend on the wiring to those switches, if there is a neutral at the switch then that should be fine. If there isnt a neutral then ideally you would want to run one but if thats not possible then the dimmer 2 can be run without a neutral but you need to have a minimum load on the circuit of around 20W (the spec says 10w but take that with a pinch of salt) . If the load isnt 20w then you need to add a Shelly bypass ( basically a smart dummy load).
The wiring diagram is also different see below
Smurfin
Stupid question time. I have 2 lighting circuits which are controlled by a 2 gang plate with 2 switches, and they control the separate circuits. Do I need a dimmer2 for each of the 2 lighting circuits? (if so I'm wondering how that would work in terms of fitting 2 within one backbox!)
Smurfin
hmm I see the Ring 10 piece alarm kit is on offer for £199 today...something of a bargain. I would like to integrate everything, but the price difference is huge - I guess the only thing I would want to do is for the alarm to trigger lights with specific events, but not sure that justifies the cost!
Any thoughts?
Smurfin
Well I have to say, this has been something of a disaster so far!
The dimmer2s are unusable due to:
Every circuit suffers from flickering lights, regardless of the brightness setting (I’m using the bypass and everything is wited
One dimmer2 keeps shutting down the lighting circuit due to overheating
Frequent WiFi drop outs showing devices offline
The dimming range is very poor (could be the lamps)
The Varilight retractive switches feel horrible to use - and only the down switch works for both on/off and dimming…using it as a dimmer is best to impossible as the light jumps pretty much from off to on
My electrician is just about to take everything out and install normal dimmer switches while I work out how to move forwards .
an exercise in frustration so far it must be said!
my light fittings are ansell with Integral GU10s but I don’t think they have anything to do the problems
Seb Briggs
If circuits are flickering then it’s definitely a load or fitting problem especially if all dimmer 2 have the same issues
if one is overheating then it’s overheating and protecting itself
WiFi dropouts are down to coverage especially as the modules are in walls so coverage has to be rock solid
if varilight switches not working they are either wired incorrectly or not set correctly in the app
are you sure your leds are actually dimmable
Seb Briggs
Shelly Module
Did you do the above before fitting , as you probably could have ironed out the issues before full install ?
Smurfin
quite a few reported issues with flickering it seems. Definitely wired correctly and all circuits with bypasses.
I’m not quite sure what there is to iron out…it’s all been done correctly. I’m a little stressed right now as in the process of sanding floors, moving house tomorrow!
Back to the automation drawing board I think…
Seb Briggs
Flickering is a load issue
do you have a link to the model of downlighting used
if it was done correctly you wouldn’t be having the issues I’m sorry to say
I understand the frustration but best to make sure everything is correct before dismissing the solution otherwise you may end up keep being frustrated
Setting in app is dual button mode
Latest News
Sony announces two new 3LCD laser projectors
  • By Andy Bassett
  • Published
Ruark Audio R5 is Made In England collection launch product
  • By Andy Bassett
  • Published
Apple unveils MacBook Pros for 2021
  • By Andy Bassett
  • Published
Apple launches third generation AirPods with spatial audio
  • By Andy Bassett
  • Published
What's new on Netflix UK for November 2021
  • By Andy Bassett
  • Published
