Smart home CCTV
Discussion in 'Smart Home, Climate Control & Security Forum' started by jonnyMercUK, Aug 28, 2018.
  1. jonnyMercUK
    jonnyMercUK
    Apr 22, 2014
    365
    28
    +35
    I'm very much into Smart home devices, we've moved into a project property which is allowing me to put what I want in.
    I'm onto the CCTV now, i'm not sure whether to go for wired/battery powered, IP/analogue. I've seen quite a lot of hype about Hikvision which looks a good system to use if I was going down the wired route.
    Integration with my other devices would be good, so for instance Alexa. The Arlo cameras seem to do this.
    Does anyone have any advice?
  2. 3guk
    3guk
    Oct 22, 2016
    4
    Manchester
    +3
    Really depends on how you are looking to integrate it with everything else, and what you already have.
    In terms of cameras, I've installed quite a number of Ubiquiti G3 Cameras + NVR systems, I must admit I really like them, the cameras are quite visually pleasing and the quality of the video is great - integration options are fairly limited, I know you can set them to work with the Echo Show fairly easily, for me the main selling point was that they are all Power-Over Ethernet, so stupidly easy to install.
