WeegyAVLover
Hi Al,
Trying to figure out how best to setup smart lighting in my hallway as it is not the most straight-forward.
I have a few 2 way light switches and I know this is going to sound totally neurotic but I have found I hate the fact that with normal light switches that you cannot have them all aligned so ou have some in the switched on position and others in the switched off position and the lights all be off... Very OCD I know.
So I am normally install smart light switches but 2-way light switches on smart light switches does not seem to be a thing. I think I am therefore left with installing maybe something in the light fitting to allow for smart control/ Then along with this a touch light switch that I assume will go off/on when the smart control in the light turns th elight on/off?
Can anyone help with a smart solution that would work at either the light fitting end or at the socket end?
Word of warning - I have basic grasp of electricity and that is about it.
Colin.
Colin.
