Smallish tv recommendations
Discussion in 'TVs' started by duckson, Dec 30, 2004.
  1. duckson
    duckson
    Nov 26, 2004
    684
    28
    Preston
    +30
    I need a smallish TV for the kitchen but would like it larger than a 14" but it willl need to be under 20" as its going to go on a ledge thats quite small (~40cm deep) plus it will be at an angle....so can u get CRT's that are 16-19"?
    I dont want to spend a fortune hence i dont want an LCD, my budget is ~£150.
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Duckson,
    There are dozens of 16-19" tv's available.
    Try Kelkoo or similar and you'll be spoilt for choice. :laugh:
    Good luck. :thumbsup:
