Smallish room setup / Japan imports.
Discussion in 'Projectors, Screens & Video Processors' started by NeilMcRae, Feb 3, 2003.
  1. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    I'm looking to install a projector and screen. The screen would put into a bay window and there would be about 7 feet between the screen and the projector. Looking at a 90+ inch screen 16:9. As its a smallish setup I'm think the AE-100 might do the trick but I don't want to buy this only to end up "upgrading" to an HS-10. Anyone here have an opinions on this? Sanyo Z1 is also an option here I guess.
    Also, from the EU prices on pricejapan.com it doesn't seem like its worth importing from them [especially if you get stung for the VAT] has anyone used them and how much did you save?
    Regards,
    Neil.
  2. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +239
    Hi Neil,
    If you haven't already I would recommend you go to a shop and ask to see a 7ft screen 7ft away. I think the recommended distance from the screen 1.5x the size of the screen.
    I have a Z1 with a 7ft screen. I sit about 13ft away and my Z1 sits about 9/10ft away from the screen. I have another sofa along the side wall. I sat in that the other day (approx 7ft away). I felt the picture was a bit overbearing and I could make out the picture structure...bit like beeing two inches away from a normal TV.
    go to www.projectorcentral.com. They have a thing to calculate disatances...punch in screen size, model of projector and it gives you optimum distances etc.
    Jus.
  3. Julia
    Julia
    I would suggest an AE300 (short throw and no screendoor + DVI input).
    ProjectorCentral.com has a great review on it:smashin:
    Julia
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Where did you get yours from Julia? How much?
    Neil.
  5. Julia
    Julia
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Julia - Thanks. Getting an inchy finger on that order button now :D
    Neil.
  7. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +239
    Neil,
    I'd still check out the screen size you want to get. 5ft might be ideal. 7ft+ I think it's going to be too much.
    Jus.
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Will do mate. One question, 16:9 or 4:3?
    Neil.
  9. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Neil,
    One answer - 16:9 !!
    If I understand your first post on this thread, you intend to have the projector 7' away from the screen - you haven't specified how far away you're going to sit from the screen. You should check out projectorcentral.com here and use the throw distance calculator to check how big a screen you get at 7' throw distance for each model that you're interested in. The AE300 and Z1 have fairly short throw distances while the HS10, afaik, has a longer throw. The calculator will give you a min and max figure - this corresponds to the zoom on the projector. Don't be tempted to plan on zooming the pictutre up to the max to get a big image from a very short throw - the picture quality will be badly affected. Most here would recommend minimum zoom for best picture quality. Projectorcentral.com will not recommend an optimum seating distance - the rule of thumb is between 1.5 and 2 times screenwidth.
    Good luck.
    Sean G.
  10. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Did some additional measurements
    From seat to screen its about 12 feet.
    From projector to screen its about 14 feet. Screen size would be 7 or 8 foot.
    Sound reasonable? Now can anyone recommend a screen to go with the ae-300? rolldown either manual or electric.
    Neil.
  11. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Also looking at the AE-300 - any gotchas with this? Hows the fan noise?
    Neil.
  12. Kramer
    Kramer
    Hi Neil.
    Just PM'ed you with some info.
    My inbox is clear now, so PM away ;)
  13. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    Neil
    The fan noise on the AE300 is very quiet.
    On my previous PJ (AE100), I found the fan noise intrusive whilst watching Cast Away. Because this film has a quiet soundtrack for most of the time, I found it annoying to watch.
    I only sit about 1-2 feet away max, so I'm not being overly critical of the AE100, but my new AE300 is nigh on silent in comparison, and I can now enjoy watching this film again.
    HTH.
