Small tower case - is this possible?
Discussion in 'Desktop & Laptop Computers Forum' started by mellow, Aug 28, 2003.
  1. mellow
    mellow
    I think I'm trying to find the impossible.
    I want to build a PC into a small tower case (< 24W x 33D x 35H cm), important bit is depth as it's to fit in a unit. No problem, I thought, use a mATX board and get a suitable case.
    I can't find one that is shallow enough, with 2 5.25" and 1 3.5" external bays. The miniATX cases only have 1 of each ext. bays, and the shuttles either the same, or in the case (sorry :rolleyes: ) of the Soltek Qbic too wide.
    Best compromise I can come up with is this barebones from Asus here , which is a bit short on PCI expansion.
    Can anyone come up with any other suggestions, or what's your views on the Asus? Sorry if it's a bit off topic, as the PC is more of a general purpose workhorse than a true HTPC.
  2. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,620
    Can you accomodate 1 more cm in depth ?
    The Lian Li PC-402 Case is 210X240X340mm(W,H,D)
    Lian Li PC-402
  3. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,620
    Just found another one that will fit I think
    Venus
