small square speakers
Discussion in 'Home Cinema Speakers' started by rab4169, Jul 7, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    can anyone recommend small square speakers preferably white or grey
    i want to put them on a wall ,one ontop of the other so i have two wall brackets with 2 speakers stacked on each bracket.
    this is so i can run my amp through one and my plasma through the other if you know what i mean.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sounds like to either want BOSE (YUCK) or Mission M-cubes.........but there are better sounds for the money
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    Yup, hornydragons suggestions are possibly the 'best' which fit your cube requirements. Bose have a very particular sound which people tend to love or loath - I must side with hd and say I am in the yuck camp too. The Mission get good professional reviews but the individuals on here who have heard them tend to give more mixed reviews - havent heard them personally as I am not into the sub/sat / lifestyle system type setups.
    If you consider either they should certainly be auditioned.
  4. Beobloke
    Beobloke
    Aug 10, 2004
    1,314
    Out in the Sticks!
    +66
    Mordaunt Short Premiere's come in silver, which isn't far off grey........ :D
  5. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    I'm not in the Bose (Yuck) camp :D but it sounds like they would only do what you want if you bought 2 sets of speakers.
    Small cube speakers often need a subwoofer to work along with them.
    Are you expecting sonic purity or just a reasonable sound to get the job done?
    Heres an Idea get 2 of these and split the woofers out with some judicious soldering. bridge the tweeter so it works from both sources paint to your liking and voila!
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Bose could not be run direct off the plasma unless you use a bass module with the cubes...Canton CD1 are available in silver and black ane the sats will run off the plasma amp without the sub, my question is why not jsut use the AMP all of the time?
  7. clarky78
    clarky78
    Nov 8, 2004
    1,879
    Helsinki, Finland
    +41
    Monitor Audio Radius 45. 9.5cm cube speakers with rear firing tweeters. Come ina grey colour and piano white (glossy). Seem good and come with matching wall brackets too.
