Small speakers for TV?
Daneel
Established Member
My friend is looking for an amp + speakers to use in place of her built in TV speakers (plus music from her PC). Being a lady and a little house proud, her first concern is that they are fairly small (maybe 6" max?), black and as pretty as possible!
This puts her requirements well out of my knowledge area, so I turn to you guys for help.
She has a limited budget, say £200-£250 for speakers plus amp. I think I can pick up a second hand NAD integrated from Ebay for around £50 that will do the job.
Second hand is fine for the speakers too, no stands required, she intended to put them on the same stand the TV sits on.
Any suggestions?
Andy98765
How about a little system with CD and DAB Radio
DENON DM38DAB MICRO SYSTEM - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/6773 for details Add a pair of speakers Q ACOUSTICS 1010i SPEAKERS (PAIR) (BLACK) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/3693 for details and she will have a excellent little system with the bonus of excellent quality.
BUT be warned most stero units do NOT except optical in which these days is the preferred method of connection from a TV.
But a lot of TV's will give stereo out via one of the scart sockets but you will need a scart adapter with audio breakout and then connect with a pair of phono plugs.
Daneel
Established Member
Interesting. Any idea how that compares to the Aego 2.1 M or the Audioengine A2? Those were the two I found when I went hunting this morning.
Andy98765
The speaker systems you are looking at are just that, amplified speakers.
What I have shown basically is a mini Hi-Fi system with DAB, CD and the ability of adding various bits.
Also the unit I have shown will have a remote.
The speaker systems you have looked at will still suffer the lack of optical input that the TV may require so more investigating first before taking the plunge.
Basically the ideal TV will have a analogue stereo phono output.
BlueWizard
The first thing she and you need to determine is if the TV has an Analog (meaning not digital) AUDIO OUTPUT. This will take the form of a pair of Red and White RCA-style Phono-type connecting, or it will be found in the SCART connector and can be accessed with a simple £5 adapter. The final alternative is to tap into the Headphone output.
Next is a remote volume control. The Audio Out on a TV are usually fixed level , meaning that output does not change with changes to the TV volume control. You must use the volume and remote that come with your audio amp.
In some cases, the Headphone output of the TV is connected directly to the TV volume, in other cases the Headphone volume is set in the menus somewhere. Still the Headphone out can be a good workable option if nothing else is available.
Note while external active speakers are a workable option, very few of the come with a remote control.
From you statement, we assume you need just an amp with multiple inputs, and a compact pair of speakers, and with a total price of about £250.
Here is one amp to consider -
Pioneer A209E, 35w/ch, £139-
PIONEER A209R AMPLIFIER - available from Superfi UK
If you can push a little higher, the next model up is also worth considering -
Pioneer A307R, 45w/ch, £179-
PIONEER A307R AMPLIFIER - available from Superfi UK
For speakers, while there are many, these are something of a bargain in a good speaker -
Diamond 9.0, 4" woofer, 60hz, £59/pr-
Wharfedale DIAMOND 9.0 Black | Speakers Per Pair | Richer Sounds
A larger alternative and still close to your budget is the -
Diamond 9.1, 5" woofer, 50hz, £99/pr -
WHARFEDALE DIAMOND 9.1 SPEAKERS (PAIR) - available from Superfi UK
Both these speakers are on close-out and therefore deeply discounted, but that also means limited stock and limit colors, but none the less both are speakers worthy of consideration.
As an alternative, you might be able to find the Monitor Audio BR1 for about £100 per pair. Again, on close-out and deeply discounted. For a larger speakers with better bass response, consider the Monitor Audio BR2 for roughly £150/pr. Both these speakers are on close out, and again, that means limited stock and limited colors. (You should find both in a Google search, but PeterTyson.co.uk, QuantumElectronics.co.uk, and HiFix.co.uk are known suppliers.)
Another speaker, a current model at standard price, would be the Tannoy Mercury F1, which are about £100/pr.
This by no means touches on every possibility, but it should help you get started.
All products listed with the exception of the Wharfedale Diamonds, are available from multiple sources, and should be very easy to find.
Steve/bluewizard
Daneel
Established Member
Thanks guys. It looks like my first port of call is to take a look at her TV! I just assumed that TVs all had analog RCA outputs, good thing I asked!
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
