Small speaker wall brackets...
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by dougbryson, Sep 23, 2004.
  1. dougbryson
    dougbryson
    Hi folks,
    Can anyone recommend me somewhere to get a couple of speaker brackets for small surround speakers that only have fixings on the base. In particular it's for the Denon SYS-500SD speakers that come with the DHT-500SD system. They're only 7cm wide and 16cm deep so the smaller the better.
    Thanks!
  2. lawrenso
    lawrenso
    Oct 6, 2003
    1,155
    48
    Flintshire
    +35
    Have a look at Vogels Website - they have all sorts there
    Vogels
