Small Speaker Stand with small top plate
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by 3sgte_power, Jun 12, 2005.
  1. 3sgte_power
    3sgte_power
    Jun 7, 2005
    1,182
    48
    Coventry
    +76
    I've just brought some AVI Neutron speakers and the dimensions are 140mm x 205mm x 265mm (W x D x H).
    Are there any stands out there with a small top plate, which'll fit the above criteria?
    Ideally i'd also like the height of the stands to be around 450mm, since my sofas are quite low.
