sameoldname
Hi Guys,
My brother and I are about to install a home theatre room in our parents house and are just looking for a bit of advise.
The room is 14.5ft x 12.5ft and will have floor to ceiling length velvet drapes along the entire length of the longest two side walls.
The equipment we'll be using is:
Denon AVR-2809
Monitor Audio BX2
Monitor Audio BX Centre
Mission 79DS Surrounds
SVS PB12 Plus (525watt)
SVS PB12 NSD (325watt)
Now, we may not be using both subs if they don't work well together but we have the option.
Does anyone think that buying a pair of BX5's for the fronts and moving the BX2's to the rear would be a good decision? I'm worried that even though its quite a small room that the velvet drapes will absorb quite a bit of sound and it might be worth getting the larger speakers, if only for sound cohesion.
It will be only a 5.1 system because we have no where to put the other surrounds and i do realise that the 2809 and subs are a step above the speakers we're using but they'll probably be replaced in the next few years.
Any advice is greatly appreciated
Denon AVR-2809
Monitor Audio BX2
