Small Problem. Can You Help?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Benny_t, May 12, 2005.
  1. Benny_t
    Benny_t
    Hi guys,
    I have a small problem and i was wondering if any of you might have a solution for it.
    I'm trying to set up a lipstick camera on a sailing boat and i need a VTR to record the footage being shot.
    I can't use a GD1000 clamshell as this is too big and too costly.
    So, do any of you have any ideas as to what small DV camcorder i could use as a VTR?
    I need it to have AV in/out or firewire, have a Lanc input, a mic input and a headphones out.
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Try the sony DCR-HC32, it's small and has AV in but the specs don't tell me about LANC. I have the HC40 and that does have LANC and is small enough you most needs. The 32 seems to be the same style casing. Get down a dealer and take a look at some!!
    Hope this helps
    DigiStuff
  3. AMc
    AMc
    Nov 20, 2000
    5,626
    Near Norwich
    +2,184
    I have the HC22 and it has a LANC socket under a pull off plastic blanking plate above the hand grip (along with an AV out it doesn't mention in the manual).
    Sorry to be a newbie - what is a LANC socket for?
  4. Roy Mallard
    Roy Mallard
    Local Appliance Newrok Control (i fink, or some close varient)
    It's a sony and canon (& some high panasonics) connection used back in the days of tape to tape editing as a device controller, now most commonly used to connect cabled off camera controls for zoom & focus.
    There are some devices that act as a switch, likes of a motion sensor which can send a control signal to a camcorder for security purposes.
  5. Roy Mallard
    Roy Mallard
    should read 'network'
  6. Benny_t
    Benny_t
    does this camera have the headphones out socket and the mic input socket?
  7. AMc
    AMc
    Nov 20, 2000
    5,626
    Near Norwich
    +2,184
    Thanks for the explanation - my camera has a socket to do something I don't need to do - hurrah :D!
