bluedroog
A bit lost looking at the array of options on the market….
I’d like a minimalist tv, with the least amount of plastic etc on show, shallow in depth to go on a bedroom wall.
I do however want reasonable quality, 1080 etc, ideally a smart tv (not a deal breaker), sound will be through separate system so not overly concerned with quality there.
Now I’m looking at maximum 32”, probably even a size down (don’t even know what that is these days!).
I want to keep the budget down, ideally sub £300.
Quick side question, can all tv’s be put on a swing bracket and what is a decent budget one? I don’t need to tilt or have massive movement, just literally like opening a cupboard door so can be viewed from bed or sofa.
