Small PC or small case to build one.
Discussion in 'Desktop & Laptop Computers Forum' started by smallman28, Nov 2, 2003.
  1. smallman28
    smallman28
    I am trying to find either a small size PC (1 ft square or so) or a case of this sort of size to build one myself.
    Anyone any ideas?
    I have seen some on a US site that are only 1 inch taller than a CD drive and about 10 inches in depth,this is maybe a bit extreme as I would still like a fairly decent spec if possible.
    It wouldn't be used as a HTPC source but purely for general PC use so great graphics/sound performance is not of huge requirement.
  2. BBCuk2day
    BBCuk2day
    May 10, 2003
    94
    Have you looked at shuttle mini pcs or the mega msi mini pc? Both are small and can fit just about everything you will need in them! Cant think of any sites off the top of my head google around abit to find some :)
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Try kustompcs They have plenty to choose from.
    Mark.
