Small or Larger AV Receiver??
Discussion in 'AV Receivers & Amplifiers' started by Xstyle, Sep 28, 2004.
  1. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
  2. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    Any suggestions for amp/av receiver please?
    Will be buying either the BK xls200 or the SVS pb10 subwoofer.
    Not decided on speakers yet ... probably in-wall speakers?
  3. recruit
    recruit
    Hi Xstyle,
    I would try and go with something that has good ampification and out of the 3 you are looking at the Sony has the Better amplification and if i remember rightly it had some good reviews.
    John :)
  4. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    The sub is less than I had thought for £'s ... so maybe could spend a tad more on the amp/av reciever ... if it meant much better performance!
