Small or Large?
Discussion in 'Home Cinema Speakers' started by Stellavision, Apr 30, 2003.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    Hi all
    Would you describe Mission M7D's as small or large?
    Auto settings on my Pioneer have in the past detected them as large, but I just did another auto setting with my speakers in a different position, and it now says small.
    How is it your supposed to distinguish between small or large?
    Cheers.
  2. nathan_silly
    nathan_silly
    Small.
    Speakers that can are 80hz and higher on the LF corner will have to be set to small.
    Floorstanders say around 36-40hz can be set to large, or floorstanders with built-in subs can also be set to large.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    If you are after a second opinion - still small :)
  4. nathan_silly
    nathan_silly
    What, your thingy? :)
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    What about centre's?
    My M7C2 is set by auto setup as large. Sounds OK to me, but would it be better set to small?
    As far as centre speakers go its quite a large one, but obviously not a floor stander.
  6. nathan_silly
    nathan_silly
    Small again...
    Centre freq. response- 75hz
    Rears freq. response- 75hz
