Small or Large Oberon 7s + sub c8d (DALI)
Discussion in 'Home Cinema Speakers' started by Fantastikels, May 15, 2019 at 2:07 PM.
  1. Fantastikels
    Fantastikels
    Mar 4, 2018
    4
    Spain
    Hi all,
    Yesterday I bought and placed the setup below, and this weekend I want to hook everything up to the AVR. I have one question with regards to setting the Oberon 7's to large or small.
    Room size: 5 x 6m
    Denon AVR-x3400h
    Speakers:
    Dali Oberon 7's (3meter distance from each other)
    Dali Oberon Vokal
    Dali Sub c8d (right corner)
    2x zensor pico rears
    As I understand, by setting them to small I will feed the subwoofer more instead of the 7's.
    Why should i do this? Is there another reason then preference to do this?
    Regards,
    Mr_F
  2. b1g1an
    b1g1an
    Aug 15, 2005
    659
    43
    +230
    Always Small for a surround system with subs, start with crossover at 80Hz unless they don't go that low and then it's 20Hz over the quoted lowest, ie if they'll only do 80 set it to 100 etc.
    If you want to know the ins and outs of it at length read this...
    Crossover and Speaker Settings in Relation to Bass Management
  3. Fantastikels
    Fantastikels
    Mar 4, 2018
    4
    Spain
    I will read up on the link, thank you.
    I was figuring that it would not make sense as the sub is an entry level sub..
    Still have to read up on phasing/crossover and such..
    Product series SUBWOOFERS
    Frequency Range (+/-3 dB) [Hz] 33 - 200
    Maximum SPL [dB] 109
    Crossover Frequency [Hz] 40 - 120
    Low frequency driver, Quantity 1 x 8" long stroke
    Low frequency driver, Diaphragm type Paper Fibre Cone
    Enclosure type Bass Reflex
    Bass Reflex Tuning Frequency [Hz] 49.0
    Max. Amplifier Power Output [RMS watt] 220
    Continous IEC Power Output [RMS watt] 170
    Input Impedance [ohms] 25k
    Connection Input Mono (LFE)
    RCA
    Stereo (low-pass filtered)
    Magnetic Shielding No
    Recommended Placement Floor
    Recommended Distance From Wall [cm] 10 - 30
    Functions Crossover Frequency
    Phase Switch
    Standby (Auto Power) On/Off Switch
    Volume (Gain)
    Max. Power Consumption [W] 250
    Standby Power Consumption [W] 0.4
    Idle Power Consumption[W] 10.4
    Dimensions With Base (HxWxD) [mm] 335 x 295 x 310
    Weight [kg] 10.4
    Accessories Included Manual
  4. b1g1an
    b1g1an
    Aug 15, 2005
    659
    43
    +230
    That is very small for your room size, should really be looking at a 12" for the size of room and it would also go much lower which is where the fun starts in films.
    Your 7s would come into their own for 2 channel music without the sub, but having said that, if you listen to 'modern' music it's surprising how much really low stuff there is on what seem quite innocent tracks nowadays.
  5. Fantastikels
    Fantastikels
    Mar 4, 2018
    4
    Spain
    OK, I have read up and have somewhat of understanding.
    My lowest frequencies are:
    36 for the 7's
    47 for the center
    62 for the pico
    And 33 fo the sub.
    Will start testing between 80 to ~ 60 with all speakers set to small. I have the denon avr x3400, any tips on other items configuring with the audyssey XT32?
    Do you mean that the subwoofer is to small for the room and its range is sub par?
  6. Fantastikels
    Fantastikels
    Mar 4, 2018
    4
    Spain
    And try to focus on I guess situational awareness.. :thumbsup:
