Small mp3 player
Discussion in 'Headphones, Earphones & Portable Music' started by newbie265, May 2, 2005.
  1. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    I'm also looking for a small mp3 player for my wife for holiday to hold around 200-300 songs and have good sound quality with bass and go pretty loud?
  2. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    Anyone ,she doesn't really want an Ipod just something small.
    thanks
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,209
    +3,046
    I have this one from SVP. It is the size of a matchbox and uses a SD/MMC card to store the songs. It can take up to a 1GB card.
    It is only £19.99 for the player and around £15 for a 256MB card.
    It has auto scan radio on the headphones.
    Files are transferred by USB through a cable that is plug and play with XP (no software or driver is needed). A driver is supplied for win98.
    The only thing that is missing is a album skip button. So, if you want track 20, you have to press skip 19 times.
    http://www.blankdiscshop.co.uk/acatalog/mp3.html
    My own pics.
    http://www.apah20.dsl.pipex.com/computer/mp3player.jpg
    http://www.apah20.dsl.pipex.com/computer/display.jpg
