roydonaldson
Established Member
Hi there,
Having everything working fine with my setup, I went and bought a new 4k TV, Xbox One X and Samsung 4k BluRay player. Xbox One is plugged directly into the TV, so now problems there, but the BluRay is in my rack and goes through a HDMI Matrix. This is a small 4x2 matrix with ARC. So, 4 inputs and one output to main display in living room, second output to HDMI extenders to upstairs. And I use the Arc to pull the audio back from the TV's apps to my Linn processor.
Now, add a 4k BluRay in the mix with HDCP 2.2 and HDMI 2.0 and it doesn't like the matrix.
Looking around, I can't really find anything to go in here now ??
Are there any easy options to get a 4x2 with ARC and HDCP 2.2 available ?
All I have been able to find is the Octava UHDMXA71, but it's out of stock and even then I can't see if all the specs work on this ?
Any ideas ?
Thanks,
Roy.
Any ideas ?
Thanks,
Roy.
