Small height speakers under 14cm tall?
Discussion in 'Home Cinema Speakers' started by Tufty McTavish, Sep 8, 2005.
  1. Tufty McTavish
    Tufty McTavish
    Sep 8, 2005
    2,612
    +179
    I'm after some fairly compact speakers to fit under the TFT screen on my computer, and I don't want to sit the monitor on a book to lift it up for various reasons. There's a maximum of 14cm between the desk and the underside of the monitor. Whilst this is no problem for smaller centre speakers, I'm struggling to find many packages of speakers that are quite this small for the main front L/R pair.
    I have no size limitations for the rear pair as they can sit on a shelf or be wall mounted, and a centre speaker under 14cm tall should be no bother. I cannot wall mount or place the front L/R speakers on stands, they will be sat on my desk.
    Has anybody considered anything like this before? I'm wondering about these so called 'lifestyle' speakers but I've no idea what they'd be like TBH.
    As you can probably tell this is a 5.1 PC speaker setup I'm looking into here, but I'm looking to avoid the cheapo multimedia speakers unless my height restrictions completely stuff things up.
    Thanks,
  2. ArsoN
    ArsoN
    You could always look at the Canton speakers in the powerbuy here, they're fairly small (just received mine yesterday).
  3. mgh0001
    mgh0001
    Sep 5, 2005
    483
    trafford, manchester
    +3
  4. Tufty McTavish
    Tufty McTavish
    Sep 8, 2005
    2,612
    +179
    Ooo, the Movie CD 101s are just within my max height requirements!
    http://www.canton.de/www/index.php?pg_id=15,30,moviecd101
    Dimensions (WxHxD) - Front: 9 x 13.5 x 10 cm
    Top suggestion, thanks. I'll dig some more details out on the Sony suggestion. Thanks for that too.
  5. bcopping
    bcopping
    May 24, 2005
    500
    28
    Brecon
    +46
    the castle compact lcr is 14cm tall (32 wide)
    may be a perfect fit!
  6. Tufty McTavish
    Tufty McTavish
    Sep 8, 2005
    2,612
    +179
    I've just measured the gap to check and I think I'd better revise my height limit to 13.5cm actually. That height limitation is a bit tight really, but I'll check those Castles out too. Thanks for that, exactly what I'm after - suggestions I've not come across in my hunting so far.
