Small gas canister question?...
Discussion in 'General Chat' started by Chadford, Jul 17, 2018.
Tags:
  1. Chadford
    Chadford
    Mar 5, 2006
    6,013
    LS6
    +2,588
    ...I've a number of small (450g ish) screw on gas canisters that I've no use for...
    Also, I've a small gas barbecue that gets used frequently that takes the click-on blue 'Campingaz' canisters.
    Is there such a thing as a cheap 'screw to click convertor' so I can use up the screw on canisters?
    If not I'll just bin them dispose of them responsibly.
    Ta.
  2. Doug the D
    Doug the D
    Oct 16, 2010
    9,407
    Dorset
    +15,880
    D4161D9B-5B09-4D87-94E7-E2FF213C2915.jpeg Any good?
  3. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,305
    I think that's the "wrong" way round... if you see what I mean. That's a click to screw convertor and he wants a screw to click convertor.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  4. Chadford
    Chadford
    Mar 5, 2006
    6,013
    LS6
    +2,588
    Thanks anyway, as IG said it's the other way around, I've seen a few of these whilst looking (click to screw).
    Maybe for safety reasons what I'm looking for is not available?.
  5. SteveCritten
    SteveCritten
    Aug 13, 2009
    11,053
    Caistor Lincs
    +4,820
    I get my gas from energas (they give a discount for us poor fire fighters). And the just gave me the correct connector which is easy to swap over rather than get a converter it’s only a jubilee clip holding it on.
  6. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,305
    Unfortunately, he's talking about a "hard wired device" without a hose and regulator where a small disposable cartridge clips in.
  7. SteveCritten
    SteveCritten
    Aug 13, 2009
    11,053
    Caistor Lincs
    +4,820
    Ah right I see. Not heard of or seen this system how new is it? My gas BBQ is old ha. Been thinking of upgrading though.
  8. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,305
  9. SteveCritten
    SteveCritten
    Aug 13, 2009
    11,053
    Caistor Lincs
    +4,820
    Ah the little camping ones thanks IG.
  10. Chadford
    Chadford
    Mar 5, 2006
    6,013
    LS6
    +2,588
    It's one of these...
    [​IMG]
    ...i've had the thing for years and years now. Great for two (four at a pinch) for camping or self catering holidays as it packs away quite small. More often than not I use this at home as usually I can't be arsed to get my charcoal Weber out.
  11. SteveCritten
    SteveCritten
    Aug 13, 2009
    11,053
    Caistor Lincs
    +4,820
    Smart, must admit I have never had need to even look for one but now...;)
