Small footprint DVD Player required
Discussion in 'Blu-ray & DVD Players & Recorders' started by ikon66, Oct 23, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    466
    Tyne & Wear
    +11
    Looking to buy a reasonable dvd player that has a smallish width ie less that 40cm
    would like:
    multi region
    and that would play the majority of dvd r formats
    preferably as cheap as possible as it's only for a LCD tv in the bedroom
    any recommendations and places to purchase would be much appreciated
    cheers
    Paul
  2. slowpoke
    slowpoke
    Jul 11, 2005
    1,103
    41
    Maidenhead
    +19
    i need one of these as well!!
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    you could try buying a portable DVD player with inbuilt screen, some of those also have a s-video out to hook up to another display...
    i have in the past seen narrow width players, but they are either nasty supermarket ones that were useless, or part of an all-in-one home cinema box set in somewhere like Dixons......otherwise its been a high end brand like Cyrus with their well known shoebox shape equipment.....
    but mebbe someone else here has seen a respectable one going cheap......
    try looking through What Hifi's back section where they list all the tested products, find DVD players in your price bracket and check the dimension column.....might find some there, then you can post back here again and ask if anyone has experience with them.....
  4. ikon66
    ikon66
    Mar 22, 2005
    466
    Tyne & Wear
    +11
    thanks for the reply the problem with your suggestions is the height constraint also.
    I know I could do the groundwork myself on the net but I thought someone may have already done it and had purchased one already
    cheers
    Paul
