Small centres
Discussion in 'Home Cinema Speakers' started by patmyhead, Aug 13, 2002.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    any one recermend small centre speakers like the Kef Eggs but maybe THX certified
    My main speakers are Kef ref ones
    I plan to use two speakers fed from a Denon AV1 SR
    [email protected]
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Most THX front speakers tend to be fairly large (Kef THX) or box shaped (M&K). I´ve heard it can be a bit of a nightmare getting two centre speakers to work properly due to cancellations etc. Would´nt you be better with a single large centre?? Something like the Kef Reference 200 centre or the Kef THX centre.
  3. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Thanks for reply i have been useing Kef 100c which used to sit on top of a 46" rear projection tv
    I now have a screen that comes down in front of the tv leaving the centre speaker behind the screen
    I then placed the centre on the floor that sounded allright but was prone to kids cat etc standing on it
    I had 2 old celisten speakers so i placed them under the wings of the tv this sounds ok but makes the tv look big & dare i say it ugly
    so the plan was to use 2 small decent speakers as centres
    [email protected]
  4. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    How about a stand for the centre speaker? High enough so that it comes up to the bottom of the TV screen and the PJ screen. That´ll keep it off the floor, either that or ban the kids/cat from the room!!:D
  5. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
