Small centre speaker
Discussion in 'Home Cinema Speakers' started by c_cecchi, Jan 11, 2005.
  1. c_cecchi
    c_cecchi
    I have a limited space on a mantle piece to accomodate a centre speaker (approx 15cm H and approx 10cm Depth, length is not an issue).
    I appreciate that this will probably not offer me the greatest centre speaker in the world - but that's all I've got to work with.
    Can anyone recommend a mini centre speaker?
    I had considered getting hold of a centre speaker from one of those 5.1 sets shops sell - but am unsure of how to go about it.
    Help please!
  2. MBM1
    MBM1
    Jan 4, 2005
  3. c_cecchi
    c_cecchi
    Thanks.
    The reason I need a small centre is because the TV is wall-mounted above the fire place. There is a gap of approx. 15cm between mantle-piece and TV -I want to rest the speaker on that.
    Yesterday I had a hike up and down Tottenham Court Road and have looked at:
    B & W VM1 - nice but a little big (will fit though)
    Mordaunt Short 304 - seemed round about the right dimensions - did not hear it though..
    Canton CD 50 - looked very nice and is thin but again could not hear it.
    Should I be looking at any others? Bear in mind this height issue of approx. 15cm.
    I also saw those Gallo sphere things - they look weird... can an oversized tennis ball be a centre speaker? :)
  4. Kazman
    Kazman
    Jan 14, 2004
    5,269
    Luton, Bedfordshire
    +142
    What are your other speakers?
    The MS304 is a nice little speaker for the money.
  5. Boozyuzi
    Boozyuzi
    Aug 10, 2002
    531
    Edinburgh
    +35
  6. c_cecchi
    c_cecchi
    Thanks Guys.
    For the record I have Mission 753 Primaveras as fronts and the Blue Room Micropods as rears [wall mounted].
    I will check out Canton.
