Small black box on Z2 power cable.
Discussion in 'Projectors, Screens & Video Processors' started by paulw77, Jan 20, 2004.
  1. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    Does anyone know what it is ?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    A ferrite ring? Reduces RF interference.
  3. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    How have the people who have extende their cables accomodated this box - have you just cut the plug off and extended the cable with plastic connector blocks ?
  4. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    If all else fails, you can get ferrite rings from Maplins or similar.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I haven't needed to but if I did then either I'd just ignore the loss of the core .. I'm not at all sure it's actually useful ;) .. or else do as you suggest and use an in-line cable joiner.
  6. sainthalo
    sainthalo
    just buy a convertor instead?
