Small as Possible?
martin99
Hi Chaps,
what is the smallest PC you can get for a reasonable price?
I'm a contractor, and rather than dragging round a laptop every day I want to just carry the CPU, and leave the monitor keyboard, mouse at the office.
cheers
martin
martin99
Mac-minis are tiny and will run Windows if you needed.
I have a MacBook Pro and run parallels. The problem is its too slow when running
Project and Visio.
If I use boot camp on a Mini mac do these apps run at morre reasonable speed?
cheers
martin
badbob
Need more info. Do you need a PC with it's own power supply? Or will you run off mains? I take it the unit must be usable in a single unit (ie a laptop)
What about strapping a LCD and keyboard to a atx case with duct tape?:D
Hey Martin
Maybe a Shuttle XPC is what you need. I use one as my main PC and love it. It's not as small as they go, but it fits into an over-shoulder bag nicely and isn't too heavy.
http://www.lyris-lite.net/2007/05/i_bought_a_new_monitor.html
I have 2gb of RAM, 2 hard drives, and an Intel Core 2 Duo 2.4 in there. There's also 1 PCI-E slot and 1 PCI slot so you don't need to compromise on sound quality, and hopefully not much on video if you're a gamer.
They have an AMD-based version as well.
Picture on top of my old PC tower:
