slr for taking pictures
cheeks
good evening,
im looking for some advice on a new camera plese
over the last year or so, i have got into photography quite a bit, and now im going to treat myself to a slr.
after reading 1001 reviews on the net, im none the wiser of a camera that stands out to be the one to buy. it would seem that with every new model that comes out ( canon/nikon) it is the must have camera to have.
i do not need the movies on a camera, the camera will only be used for pictures.
ive been to a couple of shops and had a fiddle and tbh i didnt really find any brand of camera to have a better feel than the other.
the camera is going to be used for shooting mostly wildlife, so something that is robust is a must.
so the question really is, are the newer models of cameras really that much better picture cameras than the older models?or should i be looking at getting one of the slighty older models and spending the rest on lenses?
my budget id around 700/800 pounds, but im not in a rush so the budget could be stretched to slighty more.
im sorry for waffling on:oops:
and thanks to anyone who takes time to reply
ziplex
good evening,
I'm in a similar position as I want to upgrade my D80 for a tougher/faster camera, I have been looking hard at a Nikon D300....only available s/h now but in your budget for the body only. May be worth checking out?
moonrakerz
10 out of 10 on your part ! Pure sales hype to get you to spend more money.
Absolutely not ! But Jessops will tell you the exact opposite, of course.
Very sensible.
my budget id around 700/800 pounds.............the budget could be stretched to slighty more.
Spend half of that on the camera and the rest on a good second lens/tripod/accessories.
Would suggest you buy the "bottom of the range" Nikon or Canon. Both are very good cameras and are well supported by a good range of "Independent" (ie: cheaper) lens manufacturers such as Sigma and Tamron which you may well want to add a little later.
( I bought a 500mm Sigma lens for my Nikon for less than £800, the Nikkor equivalent is over £4000)
Use that camera for a good couple of years - forget all the hype you will read about upgrading to the latest model, then YOU will have a good idea of what you will need for the future - it may well be the one that you have got already !!
ABOVE ALL - DON'T fall for the old "the more pixels the better line" - it is pure b******t. (Google it - and read the true story !)
My personal choice would be:
Nikon D3100 18-55 VR Kit - The Nikon D3100 from a Nikon Premier Dealer
and either
the 55 - 200 or 55 - 300 VR Nikkor lenses to go with it. (depending on the size of your budget)
or if you prefer red advertising on you camera strap instead of yellow - get the Canon equivalents.
Have fun !:D
cheeks
thanks very much for the replys guys, after speaking to my grandad who has a friend who does quite a bit of photography, he managed to produce a brand new Canon EF-S 18-135mm f3.5-5.6 IS Lens free of charge to get me on my way. so the brand of camera has been made for me (not that i am complaining). have been looking at the canon 500d, which can be picked up for about 400 pounds, body only, then the rest on another lens.
cheeks
thanks mate, noticed in a earlier thread that you owned a 500d, was just trying to find out to pm you for a bit more info.
is the picture quality that much better on the 550d, than the 500d to warrant the extra 150 pounds?
Jammyb
I don't know if it's worth an extra £150, but if you look at the in UK hong kong grey imports on eBay the difference is more like £60 (£465 for a 550D)
You're getting a newer 18mp sensor with a marginally better high ISO performance, much better metering system and a nicer screen. Plus the video mode is a lot better and has a mic port.
senu
Yes, I would not upgrade to a 550 from 500D but would not if buying new not get the 550D
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
