malk
- Joined
- May 15, 2008
- Messages
- 2,815
- Reaction score
- 337
- Points
- 487
Hi there,....right,im confused....
It seems to be,everytime,i switch my ATV2 on,it gets worse...
Ive had it about 1 week now,and at first everything was fine,i set it up(well it did the set up really),i typed in the network name,and it connected,no problem.
immediately i could use itunes on my ATV.
now,everytime i use it,i have to,either,restart the router,switch itunes on and off or,unplug ATV,.,or a mix of that.
My ipad sees all my itunes movies no problem,and the music,no problem.
The ATV is JB,and im thinking its something to do with that,.
My router address is 192.168.0.1,and the ATV router address is the same.
The ATV ip address,is 192.168.0.5.
On my MBP,the wifi en1 address is 192.168.0.2
It says ,on my MBP,its using dhcp in the ipv4,and that is 192.168.0.2
The wifi address on my MBP,is different to the wifi address on the ATV,should they be the same?
I would be greatfull,if someone could look at the IP addresses etc,and notice if something was wrong,.
Also,if something was wrong when i started up the ATv,ie an IP address,would the ATV "fix"itself,to get it working?could that be why it starts to work,after not working?because the numbers ive just wrote down,are the numbers of it working,so maybe i should check the numbers,when its not working.???
I dont know,this is bugging me out a bit.
Im really confused,on why it is very tempremental.
It is the same when im using plex,and i havent had the two running together,ie not both open at the same time.
I have never really delt with ip addresses before,the most media serving i have done was using PS3 media server.
I would really like to undo the JB,and see what happens,but before i do that,i thought id ask here.
