Slowing down a Tosh DVD
Discussion in 'Desktop & Laptop Computers Forum' started by theritz, Apr 8, 2003.
  1. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    I've got a Toshiba SD-M1402 DVD drive, and it makes a fair old noise - I've read here of a utility to slow down Pioneer drives - anyone know of a similar prog/utility to slow down this drive ??
    Thanks,
    Sean G.
  2. Kramer
    Kramer
    Yep.
    Or.... I do know of a workable hardware trick that's guaranteed to work:
    Attach small lead weights to your DVDs before playing - available from all good tyre ("tire" for all our US friends) fitting joints.
    Get the self adhesive ones - don't want anything flying off now do we.
  3. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    As ever, helpful and insightful advice from you, ye big git. BTW, do you ever go to sleep or is this just latent vampire behaviour ??
    Anyone else ?? PLeeeese ?
    Sean G.
  4. Epithet
    Epithet
    The Pioneer Utiilty silences my 116 and it should also do the same for the 106S. I recently trialed a 120s (currently available at Komplett and ARIA) but I couldn't get the utility to silence the drive so I returned it.
    Others on this forum have recommended NeroDriveSpeed, not to be confused with NeroCDspeed or NeroDVDSpeed. I tried NeroDrivespeed on the 120s but it didn't seem to recognise the drive. Hope you have better luck with the Tosh.
    Epithet
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Epithet,
    Thanks for that - I'll give the NeroDriveSpped a try....
    Sean G.
