hi there, just wondering if anyone has heard of this problem....
i have a philips 28pw6515 tv thats only half a year old.
it has started to have this annoying problem that the controls dont respond for a certain amount of time.what i mean is that you press to change channel for example, and 5 minutes later it will change.
it does it with both the remote and the top controls on the tv (so its not low batts in the remote), is my tv screwed? thanks for anyhelp.
