Slow Tivo ?
Discussion in 'Digital TV & Video Players & Recorders' started by zap, Jul 21, 2002.
Tags:
  1. zap
    zap
    May 19, 2001
    285
    U.K.
    +3
    I have just bought a Tivo and set it all up, but I am not sure if it is faulty or not. Sometimes it can take about 2 minutes just to load the TV guide or it can take a long time after I have made a recording selection. On other occaisions these screens load instantly. The unit also re-boots for no reason.
    Is this normal or do I have a faulty unit ?
    Paul
  2. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    No, this is not normal I'm afraid.
    You might get a better response if you re-post this over at the Tivo Community forum:
    www.tivocommunity.com then go the UK forum.
    HTH
    dr_mabuse
  3. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I think it may be faulty - my tv guide is instant and it never re-boots
    What sofware are you running ?
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    zap,
    I agree with the posts above, mine aren't as you describe.
  5. zap
    zap
    May 19, 2001
    285
    U.K.
    +3
    The latest version of software was downloaded last night and so far i have not had any problems so I shall see if the problem is now cured.
    Paul
