Slow running fans
Discussion in 'Home Cinema Building DIY' started by nathan_silly, Jun 6, 2003.
  1. nathan_silly
    nathan_silly
    My amp runs quite hot- just adding a desk fan has reduced it from hot to the touch to barely warm!:eek: so I'm wondering how can I build slow running & silent fans above the two ventilation holes to allow for cooling?
    Even something like 50rpm should do- or maybe with a pot to adjust the speed.
    Ideally I would like 240V fans- I'll just wire them upto my 4 way plug.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Im looking for mains fans for my new pj hush box....... though im getting the feeling the noise will be rather hit or miss.
    Do you have any idea what noise figures relate to...... i see maplins 80mm at 33dbA.... though i must admit i dont know what A has to do with it.......
    Ad
  3. nathan_silly
    nathan_silly
    A weighting.
    I only need them to move a little bit of air, I reckon even 25mm fans will do. Better than just still air.
  4. cradleoffilth
    cradleoffilth
    wouldn't fans emmit rfi or emf?
  5. nathan_silly
    nathan_silly
    hmm if you're right I could just use 12v fans instead.
    I've heard that 240V fans are audibly quieter though (either brush noise or wind noise) Is this correct?
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    i have had a good look there and i cant find any fans the like of which you are talking...... they are all much much faster.
    Is 30 dbA quiet or loud?!
    ad
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    For a projector its quiet, but its still a fair amount of noise.
  8. cradleoffilth
    cradleoffilth
    have a look on quietpc.comthey have fans which are about 18db
  9. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    ok..... but considering a 0.75 inch mdf enclosure with a loudish projector in it and the fan mounted in the top...... i presume there is every chance that the projector fan will dominate?
    Ad
  10. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    Kustom PCs Fans
    Ignore the ones with fancy LEDs. You want the Papst silent fans.
    These are the dogs danglies for silent PCs. Would do your projects a treat. The 12dba 80mm model is highly recommended.
    Big A :p
  11. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    The difficulty with all these silent pc affairs is they are not 240V so require additional tranformers......
    ad
  12. clockwork
    clockwork
    Oct 13, 2002
    42
    Edinburgh
    You can get 12db &19db 80mm papst fans which are next to silent! I use them in my PC. Well worth a look!
    Try www.overclockers.co.uk
    I just took a look at the KustomPCs link.... They have the same fans there :)
  13. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
    You can slow a 240V fan down by wiring a capacitor in series with the lead. You would need to experiment to get the right capacitor value, but a good starting point would be 400V 470n
  14. nathan_silly
    nathan_silly
    Thanx for the info everybody. I've set the left/rights to small 80hz and the amps get warm now (were set to large, probably reason getting toasty)
    Sounds better anyway, room is a bit small- setting to large is a bit boomy- so can tailer the low end with the subwoofer.
