slow computer.... any ideas ?
Discussion in 'Desktop & Laptop Computers Forum' started by F1F3R, Sep 24, 2004.
  1. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    hello,
    i recently built a new computer ...
    p4 prescott 3E Ghz, 800 mhz,1mb/L2 cache.
    msi motherboard. 865PE Neo2-P
    1 meg pc3200 ddr400 ram
    win xp.
    same old h/d 18gig
    and old graphics creative labs gf3 Ti500.
    but computer seems to be very slow too bootup, and very slow to initally start programs.
    eg control panel ..after clicking into control panel the icons take a few seconds to appear.. sooo slow.
    ive looked for obvious things on computer but cant find nothing.
    ive set all bootups in bios etc to fast bootup etc , changed startup seconds from 30 secs to 5 secs , still no joy.
    ive also set computer for best performance.
    its so annoying.
    ps
    in control manager/device manager/ then COMPUTER its setting is
    ACPI multiprocessor pc ?? is this correct ??
    and still in device manager /under processors its like it has 2 processors? Intel (r) Pentium (r) 4 CPU 3.00
    then same below
    is this normal ??
    in windows task manager there is still loads off memory left and cpu usage is very low 0 - 2 percent..
    no other applications are running ,
    no viruses, or spys etc
    all drivers upto date.
    1, So any idea why it takes sooooo long to bootup ???
    2, and why it takes soooo long to open programs. ???
    3, is device manger settings correct eg showing multiprocessor and why is it showing 2 cpus in processors section. ???
    any help would be much appreciated.
  2. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    i think ive found a solution to the slow boot up.
    in bios i found APIC ACPI SCI IRQ. it was disabled so i tried enabling to see if it made any difference , its boots up alot faster now. :clap:
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    What is the HD - get yourself an 8mb cache 7200rpm HD and it will be sooo much faster at booting as well as program access.
  4. HMHB
    HMHB
    Nov 11, 2001
    26,948
    Nottinghamshire
    +5,803
    Got to agree that your 18GB hard disk could well be slowing down your computer, it's amazing how much difference a fast modern hard disk makes.
  5. mjn
    mjn
    May 24, 2001
    22,425
    Herts, England
    +10,457
    make sure any CPU cache is enabled as well.
  6. Embarker
    Embarker
    Apr 19, 2004
    1,677
    Garden of England
    +71
    if you go to pcpitstop there is a full system check that will report and recommend areas to tweek and upgrade.
    I too second it could be the hard drive, my daughters has a 4gb and that has a naff transfer rate of 1 mb/sec. It boots fairly quick but you have to wait a few seconds for programs to open, however a decent defrag helped bundles.
    Rgds
    Dave
  7. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    thnx for the info . :thumbsup:
    i will try that pc pitstop check , and probably get a new faster h/d, this mobo supports SATA hard drives so i will get 1 off them .
    thnx again.
