Slow channel change on panny
Discussion in 'Plasma TVs Forum' started by Hifi addict, Nov 8, 2004.
  1. Hifi addict
    Hifi addict
    I have seen the 37"panny last saturday and noticed that changing channels took 3 (three!!) seconds. Is that a bug on that plasma or is that normal for this device? The philips and pioneer were much quicker so it can't be something normal for plasma screens :(
  2. adrianl
    adrianl
    Was this using the Freeview or analogue tuner?
    I played with the same model in JL the other day on Freeview, and was disappointed with channel switching speed and EPG interface compared with my Sony 800U Freeview box which is excellent in those respects. I'm very likely to get a Viera though so will probably feed it with the Sony box rather than use the internal tuner.
  3. Hifi addict
    Hifi addict
    i think it used the internal tuner. Couldn't see because it was mounted on a wall with some 30 other plasma's
