Slow building HT system - need opinions on best budget speakers for music
Discussion in 'Home Cinema Speakers' started by sickbird, Sep 5, 2007.
  1. sickbird
    sickbird
    Aug 31, 2007
    84
    I am building my first HT system and bought myself an azur 540r (bit of a bargain for 179.99 from RS).
    Don't have the funds to buy the whole 5.1 shebang from the outset so looking to first buy the 3 fronts and I've narrowed it down to the following selection:
    Mordaunt Shorts: 2 x 902i and 905i centre
    Monitor Audio: 2 x BR2 and BRLCR centre
    SVS: 2 x SB12+ and the SVS centre (not sure of model number)
    All of which should be relatively close price wise around (I think) the £200 - £300 mark.
    I understand that the SVS will probably ultimately deliver the best HT/5.1 experience but I'll probably be listening to a lot more music in stereo rather than using the full 5.1 (probably 80% music) and music wise SVS reviews have not been great.
    Anyone know which set is best for music or have any other suggestions?
  2. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    MA BR2's will be the best for music (and as they're the most expensive, so they should be).
  3. Andori
    Andori
    Dec 7, 2006
    1,336
    63
    Lincoln
    +220
    I assume you actually mean te SBS-01 and SCS-01 speakers, not an SB12+ as thats the "baby" sub:devil: (think they are the numbers, not at home so can't check on mine)
  4. sickbird
    sickbird
    Aug 31, 2007
    84
    yes, I think you're right on the model numbers.
    I've just noticed your sig and you're running a very similar set up to mine - I've a LE46M87BDX, V+, xbox360 - the TV is superb isn't it?
    Looks like the MA BR2s are the way to go then...
    thanks for the help gents
  5. finchy2k40
    finchy2k40
    Sep 7, 2007
    64
    11
    preston
    i have the 902is and bought them as a replacement for my celestion 3 mk 2s and with the right gear, on a budget they sound second to none!!
  6. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    The MA's and MS's sound actually quite similar, I reckon the MA's are worth the extra money though.
  7. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    You recommend them over the SVS. Have you heard them?
    Russell
