slopping picture
Discussion in 'General TV Discussions Forum' started by tamc98, Aug 13, 2001.
  1. tamc98
    tamc98
    Aug 13, 2001
    10
    Nottingham
    I have a JVC AV-28WT5 and I have been very peased with it up until the other day. I moved the set to a different part of the room and ever since then the picture slopes from left to right.<br />Is this a fault with the set or something that can easily sorted. <br />Any info will be appreciated.
  2. webster
    webster
    Can you adjust this using a picture tilt option in the menu? This is there to compensate for changes in the magnetic field of the earth!
    Sounds daft, but it might be there.
    Simon
