Slingbox Solo remote control problem
thedon99
Apologies if this is in the wrong forum area, but I've just bought a Slingbox Solo to link to our Humax PVR (9150T).
It seems to work fairly well apart from one big issue - when pressing the up/down/left/right nav button on the onscreen slingbox remote, the cursor position jumps two places making it impossible to navigate through non numbered menus.
I've used the 9200 settings as the 9150T isn't listed (appreciate I should've checked this beofre buying) - but I though most Humax boxes probably uise the same remote.
Does anybody know how to solve the problem?.
Thanks in advance
Jim
