slimline receiver
Discussion in 'AV Receivers & Amplifiers' started by octopus, Aug 30, 2005.
  1. octopus
    octopus
    Can somebody recommend me a slimline receiver that takes up as little room as possible. I am a total novice in these things. My budget is around £200. Any advice on best places to buy ex-display or ex-demo will be appreciated as my budget is very limited.
    thanks in advance.
    RS :confused:
  2. systemsdead
    systemsdead
    Jan 19, 2005
    10,755
    grimsby,canada
    +4,841
    Cambridge Audio Azur 540Ris what im thinking, slimmer than the rest and gets real good reviews 50 quid over your budget though,check richer sounds webpage for more info
  3. octopus
    octopus
    Thanks.
    Not sure whether anybody has any reviews on the SONY STRDB900 which is available from empiredirect for around £190 inc. delivery??
  4. Steve T
    Steve T
    Aug 30, 2000
    438
    Redditch
    +3
    There's a review of the STRDB900 on this very site:
    Link to STRDB900 review
    Looks like a few shortcuts have been made to accomodate the "slimness" of the unit (I've no experience of the model though). It might be worth checking out a demo.
    Like already recommended, the CA Azur 540R comes highly regarded although slightly over budget.
  5. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    Pioneer do a range of slimline receivers. They have, however, fairly limited connectivity. Three SCART(2 RGB) inputs for audio/video,one SCART output (RGB), 3 Digital audio inputs (2 optical, one coax) plus front panel analogue phonos. I have the VSX C301 with an XBOX,DVD Player and VCR plugged in. This was £139 from Richers.
    EDIT:
    Oops!, just realised you're not after an AV receiver. Sorry!
