Slimline processor
Discussion in 'AV Receivers & Amplifiers' started by huwg, Sep 21, 2004.
  1. huwg
    huwg
    Oct 23, 2003
    1,852
    +121
    Can anyone recommend a slimline procesor with amplification for the surrounds and centre?
    I want to use my Audiolab 8000S to drive the main stereo speakers, as it is my main hi-fi amp.
    If there is no bolt-on processor, then a slimline amp will suffice. I see Denon do the sort of thing I'm after, but are there any others?
    Budget is small (up to £300)
    I asked this question a long time ago, and the Yamaha (not very slimline) was the suggested model, has the market changed very much?
  2. huwg
    huwg
    Oct 23, 2003
    1,852
    +121
    Sorry, just realised that this would be better off in the 'Processors' forum,
    can someone shift it for me please?
