Slimline Kit
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mike-M, Jan 1, 2005.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,376
    48
    Lincoln
    +39
    Following a furniture change,I need to replace my DVD kit. I only have room for slim boxes and was wondering which was best.
    I can only find three things that seem to suit they are the
    Denon 770 combo
    Yam RXSL100/DV-SL100
    Panny SAXR50/DVDS97EBS
    My speakers are the MA radius. 270's front, 225 centre and 90 rears.
    The system will be only for movies and must have Pal Prog Scan.
    Anyone got any of the above or can suggest other possibilities?
  2. nictry
    nictry
    Apr 28, 2002
    5,773
    Kent
    +645
    Toshiba 340e only 50 mm high and does PAL prog scan.
  3. Dean
    Dean
    Jun 20, 2003
    2,890
    London
    +264
    Pioneer DV-575A is 55 mm high and also has PAL progressive scan
