ferrytrip1
I will build my first HTPC and want slim case and low noise. Sliverstone LC-19 is high on the list. I realise this may come with restrictions and would like advice.
Other h/w will be i3 2100T, Zotac H67 -ITX WiFi (subject to other issues), BD reader, TV card. Will use existing 2.5 laptop HDD or get new SSD.
Basic use will be stream media files from NAS, music into Amp, HD video from Blu Ray player and HDD to TV. Will want a TV card and temp storage of files prior to moving to NAS. Basic internet etc. No heavy use as other desktop can do that.
Questions: I have run a few Wattage calculators found via google, each of these suggest the power required is over 200W. This case comes with a 120 power supply. Am I missing something - is the supplied PSU simply not good enough for the equipment it is supplying?
If I come across the 24fps issue I will need a gpu. Appreciate the m/b will need a review, but from a case perspective is it possible to have both a TV card and video card?
Can this setup be truly silent - a CPU fan will surley make some noise - any silent ones out there?
Simon
Simon
