Slim Wall Mount: Panasonic TX42-VT30B
Discussion in 'Home Cinema Buying & Building' started by Dave.bfc, Sep 7, 2012.
  1. Dave.bfc
    Dave.bfc
    Jan 23, 2006
    15
    Hi folks,
    Having recently purchased a 42" VT30, I'm looking to get it wall mounted and have been assessing the wall bracket options.
    My house is timber framed so the wall is a stud partition so I am slightly worried about it holding the weight of the TV.
    Can I ask if anyone has any suggestions as to the type or specific wall bracket to use?
    I have seen a few cheap options similar to the following, but wouldn't mind paying more for a better, more quality solution:
    http://www.amazon.co.uk/Designer-Habitat-PREMIUM-Wall-Bracket/dp/B003U46SWC/ref=dp_cp_ob_ce_title_0
    Thanks in advance.
