slim ps2 help
Discussion in 'Playstation Forums' started by tjmartin1978, Jul 27, 2005.
  1. tjmartin1978
    tjmartin1978
    Hi there
    ive recently purchased a new silver slim ps2.
    ive hooked up an optical cable for sound
    however, im using the provided cable to connect to the TV.
    I have a Sony KV-32FQ80U television with two RGB scart inputs on the back an would like an RGB cable to go from the PS2 to the scart socket..
    I have tried my current cable in the RGB scart socket but when switching to RGB in the PS2 menu there is no visual difference.. I guess as its not an RGB cable...
    I dont have component connections on my TV but figure that RGB scart is the next best thing....
    where can I buy a GOOD RGB cable, one you can reccomend...
    Many thanks for your help
    Tim
  2. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +69
