Slim centre speaker?
Discussion in 'Home Cinema Speakers' started by doctorjuggles, Apr 1, 2005.
  1. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    Hey all.
    Looking for a good centre speaker but I have to keep it as slim/small as possible, because I've just bought a pair of B&W DM604 S3s that are huge. Missus won't allow anything too large as the centre channel now because, to be fair, the speakers will just dominate the room if I go for something like the LCR60 or something.
    So the requirements are as follows:
    - Nice and slim. The smaller the better (within reason, it doesn't have to be dinky Bose sized.)
    - Preferably very good midrange and treble performance. The 604s will be handling most of the bass, the centre won't need much grunt on the bottom end.
    - Black finish. Has to be available in black (not hard, most things are as far as I've seen.)
    - Anything between £100 and £250, more if it's a really, really highly recommended option.
    Thanks for input.
  2. Astaroth
    Astaroth
    Suspended
    Jun 22, 2004
    3,653
    2
    London
    +882
    Are you looking at the speaker as a long term solution or just until you can talk the missus arround?
    If it is long term I would not recommend going for any centre other than the matching B&W due to the issues of matching the fronts tonally - it may be best to let the fronts ghost the centre.
    If it is only short term then something like the Mission M7c1 (£50) or M3c1 will do - it isnt a great speaker but is very slimline and the fact it wont match the fronts may strengthen your arguement with the other half :D :devil:
  3. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    It's kind of a mix between the two. I'd say we'll be moving to larger premises in about 3 years time, at which point I'll match up the centres with the floorstanders. This is until then, so I don't want to buy a poor quality centre that I'll hate for the next few years, but I really do have to compromise with this, because the speakers are massive, this is one occasion where the missus is actually right. (Don't say it too loud though.)
    Anyway, she's compromising letting me keep such monsters in the lounge, the least I can do is reciprocate with her request for a smaller centre.
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    3 years?! Sell the fronts and get 3 speakers that match *now* ;)
  6. RohanM
    RohanM
    Jun 4, 2004
    357
    London
    +29
    You'll be amazed how important the centre channel is. Honestly, don't overlook it.
    I bought an LCR3 to go with my existing 603S2s, as I physically couldn't get anything bigger in the TV stand at the time, and regret it. (really wanted the LCR60, which was what I demo'd the Denon 3805 and REL sub with - oh yes, you really do need a subwoofer, too! :eek: )
    The LCR3's good, but doesn't quite do it...
    Whenever I change the TV, and hence need a new stand (the current one is integrated with the telly) I'll be upgrading the centre, too.
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I think that will be your best option, you won't be losing much if anything as long as you are careful in locating your front pair.
  8. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    Very true and costs a lot less. It also has huge WAF as theres nothing there:D
